Arducam Official online shop
Summary
This text will be hidden
108MP USB 3.0 Camera Evaluation Kit, Motorised Focus
(USB3 Camera Shield UC-593 Rev.C) -
Jeson Nano aarch64 -
https://www.arducam.com/docs/usb-cameras/sdk-and-examples-for-nvidia-jetson/ -
ArduCam_Py_Demo.py in the Streaming Demo folder succeeded in running at a size of 4000x3000, but failed to run at a size of 12000x9000
The error I received is as follows.
lsh@lsh-desktop:~/ArduCAM_USB_Camera_Shield-master/Nvidia_Jetson/Python/Streaming_demo$ sudo python ArduCam_Py_Demo.py ArduCAM_108MP_MIPI_2Lane_RAW8_12000x9000_1.4fps.cfg
('color mode', 0)
('open fail,rtn_val = ', 65361)
Is this a driver compatibility issue with the usb connection or is there an error in the 108mp (12000x9000) config file within the latest github Jeston nano folder?
I don’t think it’s the former because there was no problem with using the 4000x3000 config file.
lsh@lsh-desktop:~$ dmesg
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5494-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Apr 20 14:25:12 PDT 2022
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29760(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3560280K/4159488K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 124072K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 20.823332] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 20.843973] usb 2-1.1: LPM exit latency is zeroed, disabling LPM.
[ 20.846027] usb 2-1.1: New USB device found, idVendor=04b4, idProduct=03f2
[ 20.846093] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 20.846858] usb 2-1.1: Product: FX3
[ 20.846874] usb 2-1.1: Manufacturer: Arducam
[ 31.864577] vdd-fan: disabling
[ 31.864619] vdd-usb-vbus: disabling
[ 31.864650] vdd-usb-vbus2: disabling
[ 31.864744] vddio-sdmmc3-ap: disabling
[ 31.865703] avdd-io-edp-1v05: disabling
[ 31.865743] vdd-usb-hub-en: disabling
[ 1659.830536] usb 2-1.1: USB disconnect, device number 3
[ 1659.886921] usb 2-1: usb_suspend_both: status 0
[ 1659.887081] usb usb2: usb_suspend_both: status 0
[ 2703.145259] usb 2-1.1: new SuperSpeed USB device number 4 using tegra-xusb
[ 2703.166296] usb 2-1.1: LPM exit latency is zeroed, disabling LPM.
[ 2703.168267] usb 2-1.1: New USB device found, idVendor=04b4, idProduct=03f2
[ 2703.168659] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2703.168706] usb 2-1.1: Product: FX3
[ 2703.168751] usb 2-1.1: Manufacturer: Arducam
Cause of the problem and how to solve it
