Arducam 1080P USB Webcam camera plug-in broke, UC-692 board damaged on Windows 11
Posting here because I’m stuck. I have the Arducam 1080P USB Webcam - the one with the 2.8-12mm varifocal lens, IMX291 sensor, built-in mic and the mini tripod. It worked fine for a while on my Windows 11 PC, then it just quit working. When I looked at it, I realized the USB cable plug-in on the camera side has broken after only a few uses. It’s clearly physical damage and I don’t think the plug-in is fixable. The board inside has a stamp that reads UC-692. Any idea what I can do? I haven’t had any trouble following instructions or anything, it’s just that the connector seems to have snapped.
Hi, thanks for the detailed report. If the USB connector on the camera side is physically broken, that would explain why it worked and then quit. A few things to help confirm what’s going on: 1) Can you post a clear close-up photo of the broken connector and the cable end so we can see exactly what snapped? 2) Can you re-check the camera cable and the connector on the camera board (the UC-692 board) once more - make sure there are no bent pins and that it’s fully seated? Also, does Windows show anything at all in Device Manager when you plug it in?
I’ll get a photo up shortly. I re-checked like you said - the USB plug on the camera side is cracked right at the plug body, and the contacts are exposed, so there’s no way to keep a stable connection. It’s honestly not repairable on my end. Windows doesn’t detect anything in Device Manager when it’s plugged in, nothing shows up at all. The board near the connector is the UC-692. It was definitely working before this, it just quit.
Got it. One more thing to rule out the cable itself vs the connector on the camera: do you have a spare USB cable you could try, just to see if Windows picks anything up? If the connector on the camera side is the broken part, a different cable probably won’t help, but it’s worth crossing off the list.
Tried a different cable - no change, still nothing in Device Manager. Since the connector on the camera is what’s damaged I figured a cable swap wouldn’t matter, but I tested it anyway. So it really looks like the camera-side plug-in is the problem, not the cable and not my PC.
Thanks for testing that. Given the cracked connector on the camera side, this is a mechanical failure of the USB plug-in rather than a driver, firmware, or software problem - so there’s no Windows 11 setting, log, or code change that would bring it back. The UC-692 stamp helps identify the exact board and connector involved. I’ve sent you some follow-up details through a private message, so please check your messages there.
Got your message, thanks. I’ll follow up there. Appreciate you helping me narrow it down to the connector.
