Hi, I’m trying to run six AR0234 cameras (B0429) through the Jetson’s internal ISP on an AGX Orin dev kit, and the image comes out massively overexposed. We’re using the Jetvariety driver. The normal Python arducam_displayer app streams each camera fine, and gstreamer with v4l2src also gives usable output. But we need the internal ISP and the other hardware acceleration paths, which means going through nvarguscamerasrc. Since the Jetvariety driver isn’t seen by nvargus, we customized the driver so NvArgus can see the camera. Now frames do go through the internal ISP, but the output is completely washed out/overexposed. Any pointers on what to check?
Thanks for the detailed setup info. Just to narrow it down: when you run the stock Jetvariety driver and the arducam_displayer Python app, the image is normal? And v4l2src also looks normal? If both of those are fine, the sensor itself is probably okay and the overexposure is coming from the NvArgus/ISP path, not the raw capture.
Correct. With arducam_displayer all six cameras stream fine individually, and v4l2src in gstreamer gives normal-looking video. The overexposure only shows up when I use nvarguscamerasrc after making the driver visible to NvArgus. Also, is there a datasheet for the AR0234 and any documentation on the register settings for exposure/gain? I’d like to check whether the sensor is being configured with sane defaults before the ISP gets the frames.
That’s useful—it points to the driver/ISP configuration rather than a camera fault. To use the internal ISP on AGX Orin you do need nvarguscamerasrc, and the stock Jetvariety driver isn’t compatible with nvargus. What you’ve done is essentially a custom driver modification to expose the camera to NvArgus. The overexposure could mean the ISP is applying default AE/AGC values that don’t match the mode data the sensor is reporting, or the sensor modes/exposure ranges aren’t being populated correctly for NvArgus. Have you defined the sensor mode and exposure/gain ranges in the NvArgus-facing part of the driver, or did you only register the device?
We mostly got it recognized by NvArgus and confirmed frames are being processed by the ISP. We haven’t tuned the mode tables or exposure/gain metadata for the NvArgus side—that’s probably where it’s falling apart. We don’t have the AR0234 register-level details to fill that in properly, which is why I asked about the datasheet and exposure/gain docs.
Right, that matches what I’d expect. There’s no hardware limitation stopping the AR0234 from using the Jetson internal ISP—the blocker is driver support. The stock Jetvariety driver isn’t compatible with nvargus, and there’s currently no separate AR0234 driver adaptation planned. A customized driver that implements Nvidia Camera Core compatibility is the route, and the overexposure you’re seeing is likely because the NvArgus-facing mode/exposure metadata isn’t filled in yet. Nvidia’s docs for enabling Camera Core compatibility are here: Welcome — NVIDIA Jetson Linux Developer Guide 1 documentation and Camera Software Development Solution — NVIDIA Jetson Linux Developer Guide 1 documentation. For AR0234 driver customization specifically, you’d need to contact Arducam sales. On the datasheet and exposure/gain register docs, I can’t post those publicly, but I’ll send what’s available through PM.
