Hey everyone, I’ve been using the IMX219 V3Link Camera Kit with my Raspberry Pi 4 and it’s been working great. But now I’m trying to swap the camera module. I have an AR0234 2.3MP Wide Angle camera that I want to use instead.
Here’s what I did:
Removed the IMX219 camera module from the serializer
Plugged the AR0234 module into the serializer in its place
Connected the serializer back to the V3Link adapter board on the Pi 4
But no camera is detected at all. I ran libcamera-hello and it just says no cameras available. The IMX219 setup was basically plug-and-play so I assumed the AR0234 would work the same way since it’s also a MIPI camera. Am I missing something obvious here?
Thanks for the detailed description. Let’s narrow this down before we dig too deep.
Can you try one thing first — disconnect the AR0234 from the V3Link serializer and plug it directly into the Raspberry Pi 4’s native CSI ribbon connector? Just the bare camera module, no serializer or V3Link adapter in the chain.
This will tell us whether the camera module itself is functional and whether the issue is specifically with the V3Link path or something else.
Good call. I just tried it — pulled the AR0234 out of the serializer setup and connected it straight to the Pi 4’s CSI port with a ribbon cable. And it works fine that way. Camera is detected and I can capture images without any issues.
So the AR0234 module itself is definitely good. The problem only happens when it goes through the V3Link serializer and adapter board. The IMX219 works through that same V3Link hardware though, so the serializer and adapter board aren’t broken.
That’s helpful — it confirms the issue is specifically about compatibility between the AR0234 module and the V3Link Kit.
Here’s the root cause: the V3Link Camera Kit is designed to work with cameras that use Raspberry Pi’s native camera drivers, specifically the IMX219 and IMX477. Those are the only sensor drivers that the V3Link firmware currently supports. The AR0234 uses its own non-native driver, so when you plug it into the serializer, the V3Link firmware doesn’t know how to talk to it. That’s why libcamera-hello sees nothing — the camera layer doesn’t even get initialized properly over the V3Link bridge.
This isn’t a hardware fault, it’s a firmware/driver mismatch.
Unfortunately there’s no simple config change that will fix this — the V3Link firmware itself would need to be modified to support the AR0234’s driver stack. It’s not something you can resolve on the Pi side alone.
That said, a custom integration might be possible. Arducam does offer custom solutions for scenarios like this where a non-native sensor needs to work with the V3Link platform. I’d recommend reaching out to their sales team at [email protected] to describe your use case. They can evaluate whether a custom firmware build can support the AR0234 on V3Link and provide a quote if it’s feasible.
In the meantime, I’ve shifted to a different setup. I’m now trying to use the V3Link adapter board with a Raspberry Pi Compute Module 3+ on an I/O carrier board. I’ve made several attempts to connect the V3Link adapter to the carrier board but nothing works. There’s no dedicated CSI connector on this carrier board like the Pi 4 has, and none of the existing guides I’ve found cover how to hook up the V3Link kit to a Compute Module carrier board.
Has anyone here gotten this working? What am I supposed to connect where?
Yeah, the Compute Module carrier boards are a different beast compared to the standard Pi boards. There’s no CSI ribbon connector, so you need to take a different approach.
Here’s what you need to do:
1. GPIO wiring: Use jumper wires to connect the V3Link adapter board to the Compute Module 3+ carrier board’s GPIO pins. The adapter wasn’t designed to plug in directly — you’ll need to wire the appropriate pins manually. The specific pin mapping will depend on which GPIOs the CM3+ exposes for the camera interface.
2. Device tree overlay: Unlike the Pi 4 where the camera overlay is often loaded automatically, the CM3+ needs you to explicitly enable it. Add this line to your config.txt on the boot partition:
dtoverlay=imx219
This tells the kernel to load the IMX219 driver and configure the camera interface on the GPIO pins.
3. Reference: Raspberry Pi’s official Compute Module documentation covers attaching camera modules in detail. Give this a read:
That’s super helpful, thank you. I didn’t realize the GPIO wiring was the way to go — I was hunting for some kind of adapter or header that didn’t exist. And the dtoverlay=imx219 line in config.txt was definitely not something I had added.
So just to confirm: once I wire the V3Link adapter to the correct GPIO pins and add that overlay line, the CM3+ should recognize the IMX219 camera through the V3Link chain the same way the Pi 4 did? And the reference doc you linked covers which specific GPIO pins map to the camera interface?
Exactly right. Once the GPIO wiring is correct and dtoverlay=imx219 is in your config.txt, the CM3+ should see the IMX219 through the V3Link chain just like the Pi 4 did — the V3Link transport is transparent to the Pi once the camera interface is properly configured.
And yes, the linked documentation covers which GPIO pins on the CM3+ carrier board correspond to the camera signals (CAM_IO0, CAM_IO1, SDA, SCL, etc.). That’s your wiring reference.
Quick summary of the key difference: standard Pi boards give you a dedicated CSI connector that handles everything, but the Compute Module carrier board exposes the camera interface through GPIO — so you need both the physical jumper wiring and the explicit dtoverlay declaration to bring it all up.
