Hey everyone, hoping someone here has run into this before. I just received an Arducam 2.3MP AR0234 Color Global Shutter Camera (SKU B0429) for my Jetson Orin Nano running L4T 36.5 / JetPack 6.2.2.
cd ~
chmod +x install_full.sh
./install_full.sh -m arducam
But before blindly running it, I dug into the script and… it doesn’t look right for JetPack 6 at all. From what I can see, the script is built around legacy kernels — looks like L4T 32.x / JetPack 4.x era. It attempts to modify system files and insert kernel modules that don’t line up with what JetPack 6 expects. I’m honestly worried that running this could cause a kernel panic or at minimum leave the system in an unstable state.
Has anyone actually run this script on JetPack 6.2.2 without issues? Or is this camera effectively unsupported on newer L4T releases?
Hi there — good questions, and I appreciate the caution. I want to clear up a few things because the script is actually compatible with JetPack 6.2.2, even if the internals look concerning at first glance.
Here’s how it works: install_full.sh v0.0.3 auto-detects your system version (L4T release, kernel version, etc.) and then downloads the correct .deb package for your setup before launching the installer. It doesn’t blindly apply legacy modules — it branches based on what it finds.
It also creates a backup directory at /boot/arducam so your original kernel configuration is preserved. It won’t overwrite or corrupt your system kernel.
That said — there is an important limitation you should be aware of. The AR0234 camera uses the Jetvariety driver, which bypasses the Jetson’s native ISP pipeline entirely. This means the video stream will have a persistent green tint because the onboard ISP isn’t processing the Bayer data. There’s no software-side color correction available through the standard JetPack ISP tools for this configuration.
Thanks for the detailed explanation — that helps clarify the auto-detection logic. I hadn’t traced through far enough to see the version branching, so I’ll take your word that it’s safe on 36.5. The backup directory under /boot is reassuring too.
But honestly, the green tint issue is a pretty big deal for what I’m working on. I need usable color output — this isn’t just a preview feed, it’s going into a machine vision pipeline where color accuracy matters. If the Jetson ISP can’t touch the stream at all because of the Jetvariety driver, that’s a fundamental problem.
Is there any workaround here? Some kind of userspace debayering or a way to route the frames through the ISP after the fact? Or is this just a hard architectural limitation of how the driver sits in the stack?
Unfortunately it’s a hard architectural limitation with this particular camera module. The Jetvariety driver captures raw frames and presents them through a V4L2 interface that the Jetson’s hardware ISP pipeline doesn’t know how to ingest. The ISP chain (Argus → ISP hardware block) expects frames coming through the native camera framework, and the Jetvariety path simply doesn’t plug into that. You could theoretically do CPU-side debayering in userspace, but that’s going to be slow on a per-frame basis and won’t leverage any of the hardware acceleration.
If color accuracy is a requirement for your pipeline, the better fit would be the newer revision of this camera that includes an onboard ISP chip — it handles color processing on the camera itself before the frames even hit the Jetson, so you get vivid color natively through the same V4L2 interface:
Appreciate the candid explanation and the suggestion. I looked at the onboard ISP variant but at this point I’m going to take a step back and re-evaluate the whole approach.
Between the green tint limitation (no native ISP path), the kernel-level driver dependency that could break across L4T updates, and the fact that I’d be relying on a driver that sits outside the standard JetPack camera stack — it’s too many points of friction for a production system. We have long-term maintainability requirements and I can’t afford to babysit custom driver compatibility every time we bump the BSP.
I’m going to move to industrial-grade hardware that has first-class JetPack 6 support with the ISP pipeline working out of the box. Thanks for walking through the details — at least now I have a clear picture of what the limitations are before sinking more time into it.
