Directly from ArduCam - preorder -
B0399 -
Raspberry Pi Compute Module CM4, 4GB on Waveshare IO Board
Hardware: BCM2835
Revision: c03140 -
www.arducam.com/downloads/arducam_64mp_pi_camera_manual.pdf -
I can successfully capture “full” resolution images using libcamera-still for jpg and for yuv420.
However, when I attempt to run it as full stream, i.e. using “–mode 9152:6944:10:U” instead of the 4624x3472 format, a “failed to allocate buffers error” occurs.
Similarly, attempting to capture footages using libcamera-vid and segment at full resolution results in an error “Unable to request 6 buffers: Cannot allocate memory”, while at 16MP it works perfectly -
[ 679.210946] unicam fe801000.csi: dma_alloc_coherent of size 79552512 failed
[ 1360.943044] cma: cma_alloc: linux,cma: alloc failed, req-size: 31031 pages, ret: -12
[ 1360.943091] unicam fe801000.csi: dma_alloc_coherent of size 127102976 failed -
Reducing GPU memory, maximizing cma-size by adjusting the config.txt:
dtoverlay=vc4-kms-v3d
dtoverlay=cma,cma-size=738197504 -
Pi / memory configuration to allow jpeg encoding at full resolution and quality, i.e. no errors when:
libcamera-vid -n -t 500 --segment 1 --width 9152 --height 6944 -o test_%04d.jpeg --codec mjpeg
Software:
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
config.txt:
arm_boost=1
#dtoverlay=dwc2,dr_mode=host
#gpu-mem=128
dtoverlay=arducam_64mp
#dtoverlay=arducam_64mp,cam0
#dtoverlay=cma,cma-size=805306368 # 768MB not boot
#dtoverlay=cma,cma-size=671088640
