Hi Dion,
As for picamera2 dependencies I executed
sudo apt install -y python3-kms++
sudo apt install -y python3-pyqt5 python3-prctl libatlas-base-dev ffmpeg python3-pip
sudo pip3 install numpy --upgrade
sudo pip3 install picamera2 --upgrade
Reboot
Preview window unavailable
[0:01:04.205817214] [1561] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3897-c3c878a9
Then I ran a python script with the module picamera2 and the OV5647 camera and got
[0:04:55.549017523] [2345] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3897-c3c878a9
Camera(s) not found (Do not forget to disable legacy camera with raspi-config).
Camera init sequence did not complete.
File “/usr/local/lib/python3.9/dist-packages/picamera2/picamera2.py”, line 237, in init
self._open_camera()
File “/usr/local/lib/python3.9/dist-packages/picamera2/picamera2.py”, line 447, in _open_camera
if not self._initialize_camera():
File “/usr/local/lib/python3.9/dist-packages/picamera2/picamera2.py”, line 412, in _initialize_camera
raise RuntimeError(“Camera(s) not found (Do not forget to disable legacy camera with raspi-config).”)
RuntimeError: Camera(s) not found (Do not forget to disable legacy camera with raspi-config).
During handling of the above exception, another exception occurred:
File “/home/pi/aplicaciones/scriot.py”, line 14, in
camera2 = Picamera2()
File “/usr/local/lib/python3.9/dist-packages/picamera2/picamera2.py”, line 244, in init
raise RuntimeError(“Camera init sequence did not complete.”)
RuntimeError: Camera init sequence did not complete.
Legacy camera is already disabled.
Camera connection is okay (replacing Bullseye sd card by a Buster one camera is okay)
Thank you
PS: I get the same errors with 16MP camera attached
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
#camera_auto_detect=1
camera_auto_detect=0
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
#https://datasheets.raspberrypi.com/camera/picamera2-manual.pdf
#Dice que en /boot/config.txt es mejor borrar gpu_mem
#Lo comento
#ando probando porque se me enlentece todo y no se por que
#gpu_mem=128
#dtoverlay=imx519
