First Problem, I try to run this file “1_test.py”(from tutorial instruction above), and the command line said " Load Libarducam_mipicamera fail" After that, I changed the calling path to directory where the library isNow,I try to run “1_test.py” again, and I got an second error.Now, I have no any idea about this, and I just follow solution from others who have same error then I put this to config.txt (In red frame)I think it’s connected successfully with 8MP Sync Stereo HAT then I run “1_test.py” again, and I got third error say that “unexpected result”
What should I do next? or any part from above is wrong
I’ve try this stereo-HAT device with raspberry pi 4 and 3B, and I got same error
Please follow the steps in this document first, you can first use arducamstill to test the hardware. When you are sure there is no problem, run stereo_depth_demo
Now, I’ve follow all step refer to https://github.com/ArduCAM/MIPI_Camera/tree/master/RPI ,and I’ve try to run arducamstill and I got this"Init camera status = 4100 is shown" Is this a type of an error? I’ve change another cable and reconnect but I got the same “camera status = 4100”
