64mp camera failing on preview call
Hello
I have a 64mp Hawkeye module securely connected to a pi 4 with up to date OS. I’ve worked through the quick start guide and I think all libraries and drivers are installed.
When I test with libcamera-still -t 5000 a preview screen appears but is blank, and the attached scrolls on terminal.
Can anyone help me troubleshoot?
S
May you post pictures of hardware connection?
Hi Dion, thanks for the reply
Pretty sure it isn’t the connection, as I’ve replaced and tested with a normal pi v2 camera and it works fine… same ribbon and connections to the board
  • the camera is detected when I run —list-cameras
Sam
Here is a photo of the camera ribbon connection, and the call that shows the module is being recognised, but then goes into an endless loop of timeout on preview mode.
I can’t get easily to the other end of the ribbon as it is inside a bigger build, but the connection is good, as I said, I’ve tested it with a Picamera v2 and a Picamera HQ and both work fine.
Any suggestions welcome!
Sam
Please run the command " dpkg -l | grep libcamera" and give us the output in the terminal.
hi,
I got the camera working somehow - not sure how, but maybe it was a driver issue. thanks anyway!
