Where did you get the camera module(s)? indiegogo.com
Model number of the product(s)? 16MP Autofocus IMX519
What hardware/platform were you working on? Raspberry PI 4B + 16MP Autofocus IMX519 + ArduCam Pan-Tilt Module
Instructions from the Pan-Tilt Camera Kit
I ran:
vcgencmd get_camera
results:
supported=1 detected=0 -
[ 0.000000] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 999424
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 802816 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 997696
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1024x768M@60 smsc95xx.macaddr=DC:A6:32:A6:13:F8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=c7c3146e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3548360K/3997696K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 121656K reserved, 327680K cma-reserved, 3211264K highmem)
[ 0.000000] ftrace: allocating 34355 entries in 101 pages
[ 0.000000] ftrace: allocated 101 pages with 4 groups
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000009] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000029] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000090] bcm2835: system timer (irq = 25)
[ 0.000740] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000758] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000776] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000791] Switching to timer-based delay loop, resolution 18ns
[ 0.001050] Console: colour dummy device 80x30
[ 0.001122] printk: console [tty1] enabled
[ 0.001174] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001206] pid_max: default: 32768 minimum: 301
[ 0.001374] LSM: Security Framework initializing
[ 0.001561] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001587] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003062] cgroup: Disabling memory control group subsystem
[ 0.003297] CPU: Testing write buffer coherency: ok
[ 0.003764] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004977] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005176] rcu: Hierarchical SRCU implementation.
[ 0.006105] smp: Bringing up secondary CPUs …
[ 0.007333] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008713] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010011] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010168] smp: Brought up 1 node, 4 CPUs
[ 0.010190] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010205] CPU: All CPU(s) started in HYP mode.
[ 0.010219] CPU: Virtualization extensions available.
[ 0.011179] devtmpfs: initialized
[ 0.025474] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.025699] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.025730] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.034051] pinctrl core: initialized pinctrl subsystem
[ 0.035126] NET: Registered protocol family 16
[ 0.039196] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.039966] audit: initializing netlink subsys (disabled)
[ 0.040231] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.040848] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.041639] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.041656] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.042079] Serial: AMBA PL011 UART driver
[ 0.074504] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090849] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:02:46, variant start_x
[ 0.100862] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.141750] Kprobes globally optimized
[ 0.147281] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.151512] vgaarb: loaded
[ 0.151978] SCSI subsystem initialized
[ 0.152195] usbcore: registered new interface driver usbfs
[ 0.152255] usbcore: registered new interface driver hub
[ 0.152327] usbcore: registered new device driver usb
[ 0.152698] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.154715] clocksource: Switched to clocksource arch_sys_counter
[ 1.101095] VFS: Disk quotas dquot_6.6.0
[ 1.101188] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.101363] FS-Cache: Loaded
[ 1.101586] CacheFiles: Loaded
[ 1.102572] simple-framebuffer 3e8c7000.framebuffer: framebuffer at 0x3e8c7000, 0x300000 bytes, mapped to 0x(ptrval)
[ 1.102592] simple-framebuffer 3e8c7000.framebuffer: format=a8r8g8b8, mode=1024x768x32, linelength=4096
[ 1.103031] Console: switching to colour frame buffer device 128x48
[ 1.106992] simple-framebuffer 3e8c7000.framebuffer: fb0: simplefb registered!
[ 1.117201] NET: Registered protocol family 2
[ 1.117440] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.118950] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.118992] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.119056] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.119127] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.119294] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.119331] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.119564] NET: Registered protocol family 1
[ 1.120322] RPC: Registered named UNIX socket transport module.
[ 1.120338] RPC: Registered udp transport module.
[ 1.120353] RPC: Registered tcp transport module.
[ 1.120368] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.120392] PCI: CLS 0 bytes, default 64
[ 1.123847] Initialise system trusted keyrings
[ 1.124096] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.132440] zbud: loaded
[ 1.134186] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.134973] NFS: Registering the id_resolver key type
[ 1.135014] Key type id_resolver registered
[ 1.135029] Key type id_legacy registered
[ 1.135178] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.135194] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.136254] Key type asymmetric registered
[ 1.136271] Asymmetric key parser ‘x509’ registered
[ 1.136464] bounce: pool size: 64 pages
[ 1.136508] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.136726] io scheduler mq-deadline registered
[ 1.136742] io scheduler kyber registered
[ 1.141268] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.141299] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.141380] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.141469] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.206823] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.207212] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.207233] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.207253] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.207345] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.207589] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.211077] PCI: bus0: Fast back to back transfers disabled
[ 1.211447] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.211576] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.212010] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.215515] PCI: bus1: Fast back to back transfers disabled
[ 1.215615] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.215640] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.215725] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.215751] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.216160] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.216409] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
[ 1.225350] iproc-rng200 fe104000.rng: hwrng registered
[ 1.225663] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.226536] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.238951] brd: module loaded
[ 1.251398] loop: module loaded
[ 1.253158] Loading iSCSI transport class v2.0-870.
[ 1.258216] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.354904] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.356102] usbcore: registered new interface driver r8152
[ 1.356171] usbcore: registered new interface driver lan78xx
[ 1.356232] usbcore: registered new interface driver smsc95xx
[ 1.357866] xhci_hcd 0000:01:00.0: enabling device (0140 → 0142)
[ 1.358039] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.358087] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.361627] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.362962] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.362982] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.363001] usb usb1: Product: xHCI Host Controller
[ 1.363017] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 1.363034] usb usb1: SerialNumber: 0000:01:00.0
[ 1.363763] hub 1-0:1.0: USB hub found
[ 1.363862] hub 1-0:1.0: 1 port detected
[ 1.364536] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.364565] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.364591] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.365186] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.365205] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.365222] usb usb2: Product: xHCI Host Controller
[ 1.365239] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 1.365255] usb usb2: SerialNumber: 0000:01:00.0
[ 1.365983] hub 2-0:1.0: USB hub found
[ 1.366075] hub 2-0:1.0: 4 ports detected
[ 1.367781] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.368106] dwc_otg: FIQ enabled
[ 1.368121] dwc_otg: NAK holdoff enabled
[ 1.368135] dwc_otg: FIQ split-transaction FSM enabled
[ 1.368154] Module dwc_common_port init
[ 1.368612] usbcore: registered new interface driver uas
[ 1.368718] usbcore: registered new interface driver usb-storage
[ 1.368926] mousedev: PS/2 mouse device common for all mice
[ 1.370582] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.373935] sdhci: Secure Digital Host Controller Interface driver
[ 1.373950] sdhci: Copyright(c) Pierre Ossman
[ 1.374668] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.375394] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.379523] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.379876] hid: raw HID events driver (C) Jiri Kosina
[ 1.380071] usbcore: registered new interface driver usbhid
[ 1.380086] usbhid: USB HID core driver
[ 1.386218] Initializing XFRM netlink socket
[ 1.386261] NET: Registered protocol family 17
[ 1.386405] Key type dns_resolver registered
[ 1.386855] Registering SWP/SWPB emulation handler
[ 1.387027] registered taskstats version 1
[ 1.387055] Loading compiled-in X.509 certificates
[ 1.387952] Key type ._fscrypt registered
[ 1.387970] Key type .fscrypt registered
[ 1.387986] Key type fscrypt-provisioning registered
[ 1.399575] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.399897] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.399985] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.406871] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.407940] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.407957] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.438270] of_cfs_init
[ 1.438540] of_cfs_init: OK
[ 1.457962] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.459665] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.461365] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.464429] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.466123] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.474146] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.474829] Waiting for root device PARTUUID=c7c3146e-02…
[ 1.549948] mmc1: new high speed SDIO card at address 0001
[ 1.581852] mmc0: new ultra high speed DDR50 SDXC card at address 59b4
[ 1.582750] mmcblk0: mmc0:59b4 ED2S5 119 GiB
[ 1.584818] mmcblk0: p1 p2
[ 1.610500] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.610581] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.611174] devtmpfs: mounted
[ 1.621468] Freeing unused kernel memory: 2048K
[ 1.644761] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.665056] Run /sbin/init as init process
[ 1.665071] with arguments:
[ 1.665086] /sbin/init
[ 1.665101] splash
[ 1.665115] with environment:
[ 1.665129] HOME=/
[ 1.665143] TERM=linux
[ 1.827519] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.827541] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.827559] usb 1-1: Product: USB2.0 Hub
[ 1.829575] hub 1-1:1.0: USB hub found
[ 1.829864] hub 1-1:1.0: 4 ports detected
[ 2.014089] systemd[1]: System time before build time, advancing clock.
[ 2.104124] NET: Registered protocol family 10
[ 2.105619] Segment Routing with IPv6
[ 2.168135] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.169682] systemd[1]: Detected architecture arm.
[ 2.208927] systemd[1]: Set hostname to .
[ 2.860017] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.870581] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.870993] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.871495] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.871572] systemd[1]: Reached target Swap.
[ 2.872606] systemd[1]: Listening on Journal Socket.
[ 2.881394] systemd[1]: Starting Restore / save the current clock…
[ 2.881657] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 2.888891] systemd[1]: Mounting Kernel Debug File System…
[ 2.890235] systemd[1]: Listening on Syslog Socket.
[ 3.006835] i2c /dev entries driver
[ 3.534453] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.627974] systemd-journald[125]: Received request to flush runtime journal from PID 1
[ 4.265759] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.266353] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.269654] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.274849] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.351046] mc: Linux media interface: v0.10
[ 4.386970] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.389318] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.389346] [vc_sm_connected_init]: start
[ 4.390220] [vc_sm_connected_init]: installed successfully
[ 4.435381] videodev: Linux video capture interface: v2.00
[ 4.510228] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.520294] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.531102] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.535391] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.540308] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.543745] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.572942] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.614110] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.616852] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.797074] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.801441] checking generic (3e8c7000 300000) vs hw (0 ffffffffffffffff)
[ 4.801464] fb0: switching to vc4drmfb from simple
[ 4.802068] Console: switching to colour dummy device 80x30
[ 4.803720] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.830935] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 4.891838] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
[ 4.891865] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891881] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891896] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891911] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891926] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891941] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891956] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.891971] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.949735] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.992038] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.043812] Console: switching to colour frame buffer device 128x48
[ 5.065077] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 5.084972] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.142233] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.145869] usbcore: registered new interface driver brcmfmac
[ 5.192284] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.192900] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.193371] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.193671] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.193746] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.194249] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.194279] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.194304] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.194327] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.194356] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.194657] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.206382] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.206451] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.222618] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.222664] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.229345] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.229395] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.420334] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.420514] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.431580] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 7.176261] random: crng init done
[ 7.176285] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.209994] 8021q: 802.1Q VLAN Support v1.8
[ 7.230226] uart-pl011 fe201000.serial: no DMA platform data
[ 7.689522] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.770059] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.072587] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.072891] bcmgenet fd580000.ethernet eth0: Link is Down
[ 9.572317] broken atomic modeset userspace detected, disabling atomic
[ 11.815861] fuse: init (API version 7.32)
[ 12.237031] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.237056] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.901963] Bluetooth: Core ver 2.22
[ 13.902046] NET: Registered protocol family 31
[ 13.902053] Bluetooth: HCI device and connection manager initialized
[ 13.902370] Bluetooth: HCI socket layer initialized
[ 13.902381] Bluetooth: L2CAP socket layer initialized
[ 13.902400] Bluetooth: SCO socket layer initialized
[ 13.911200] Bluetooth: HCI UART driver ver 2.3
[ 13.911211] Bluetooth: HCI UART protocol H4 registered
[ 13.911268] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.911420] Bluetooth: HCI UART protocol Broadcom registered
[ 14.076814] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.076822] Bluetooth: BNEP filters: protocol multicast
[ 14.076835] Bluetooth: BNEP socket layer initialized
[ 14.101331] Bluetooth: RFCOMM TTY layer initialized
[ 14.101355] Bluetooth: RFCOMM socket layer initialized
[ 14.101384] Bluetooth: RFCOMM ver 1.11
[ 87.012559] v3d fec00000.v3d: MMU error from client L2T (0) at 0x1fc1000, pte invalid -
I have followed the instructions (see above) -
How do I know if the camera module is ‘dead’ or not?
