Scorpion Vision
13MP Sont IMX135
Rpi 3/4
Paper instruction
No
I’m just checking - can I use the 13MP Sony IMX135 Arducam module with the default raspistill and raspiyuv libraries. The vcgencmd get_camera gives me supported=1 and detected=0. I’ve enabled the camera, I2c and updated the gpu_mem to 180. Do I simply need to use the Arducam drivers and if so is there an alternative arducam I can use which will work with these libraries and picamera?
Thanks.
Cheers,
Neil
Executed on an Rpi
advise from above
