Topic | Replies | Views | Activity | |
How to use arducam_64mp & arducam_64mp FAQ
This post describes how to use arducam_64mp on raspberrypi. This post is a technical finishing post, if you have any questions, please open a new topic :exclamation: If you have a problem according to this post, please… |
15 | 4109 | July 14, 2022 |
Install_pivariety_pkgs.sh update and FAQ
We have updated the script to install the driver, here are some instructions. The function of automatic detection is to automatically install the corresponding driver for you when you don’t know the camera, and tell you… |
13 | 1145 | January 9, 2023 |
Using libcamera & imx519 on OctoPi
This post describes how to use libcamera & imx519 on OctoPi Nightly build. |
9 | 3206 | July 7, 2022 |
Libcamera & IMX519 FAQ
This post is used to explain some common problems with IMX519 and libcamera. |
17 | 3083 | October 30, 2022 |
How to use code to access libcamera(C++/Python)
We have wrapped the simple libcamera python library. It allows you to access libcamera through python code, and realize tasks such as turning on the camera, controlling the camera, and turning off the camera. In additi… |
63 | 14615 | January 22, 2023 |
Arducam posting rules (MUST READ)
2 | 529 | August 31, 2021 |
Serial Number Tool doesn't recognize OV9782 USB UVC camera |
3 | 31 | January 27, 2023 |
Python not able to find 'ArducamDepthCamera' Module |
0 | 2 | January 27, 2023 |
How to use IMX291 WDR mode? |
Higher resolutions on imx519 module |
3 | 18 | January 27, 2023 |
UVC Camera Adapter Board V4l2 Controls |
6 | 54 | January 27, 2023 |
Can't connect USB3 Camera Shield UC-593 to OG02B10 |
8 | 150 | January 27, 2023 |
Failed to start streaming: Input/output error |
2 | 36 | January 26, 2023 |
Set different settings for each camera of 64mp quad camera kit |
0 | 4 | January 26, 2023 |
Arducam 108Mp dev kit |
0 | 8 | January 26, 2023 |
FX3 USB camera shield windows driver
Arducam 5MP Plus OV5642 Mini SPI Camera Module on RASPBERRY PI 4B |
2 | 534 | January 26, 2023 |
ArduCAM USB3.0 Camera Shield Plus with uncompressed high fps output |
0 | 6 | January 26, 2023 |
Camaray HAT module and Syncing HQ cameras |
1 | 11 | January 25, 2023 |
Does Arducam Multi Camera Adapter Module V2.2 support IMX519 and Jetson Nano Sub? |
0 | 11 | January 25, 2023 |
OV5647 Slave Address change |
0 | 8 | January 25, 2023 |
Arducam camera shield plus i2c access |
0 | 7 | January 25, 2023 |
Remove arducam_64mp drivers and settings |
1 | 37 | January 24, 2023 |
Resolution and lense swap 12MP IMX477 with UC-512 |
0 | 9 | January 24, 2023 |
Cannot change camera properties using MSMF backend OPENCV |
0 | 8 | January 24, 2023 |
Arducam 2MP OV2311 - grab YUYV raw frame using v4l2 |
0 | 16 | January 24, 2023 |
Arducam 12MP*2 Synchronized Stereo Camera Bundle with RPi 4 camera not detected |
20 | 183 | January 23, 2023 |
Updating Raspberry Pi 4 fails |
2 | 19 | January 23, 2023 |
Problem to install IMX462 on very last version of Raspbian (5.15.76) |
12 | 63 | January 21, 2023 |
How to set manual focus distance with libcamera / 64mp / C++ |
33 | 366 | January 21, 2023 |
